Hoping someone can help me identify the component in this picture. This is a Pentair pool automation motherboard - model number 520073. The top part of the photo shows what I believe is a capacitor that has 'blown', and the bottom portion of the photo shows another area of the same board with the same component that hasn't 'blown'. The only reason I know both components are the same is because I was able to find a photo via internet search with high enough resolution to know that the numbers on top of the components are the same.
At first, I thought it was maybe a fuse, but there's no continuity on the good component, so believe it must be a capacitor.
While it's a little blurry, the numbers on the component are 47 and 6V.
Any guidance would be appreciated!
    47uF 6V Tantalum Electrolytic capacitor. You'll have to measure the physical dimensions to get an exact match. A replacement with a higher voltage rating would be fine. – brhans May 07 '22 at 03:02
    Related: https://electronics.stackexchange.com/questions/334128/how-do-i-identify-smd-components-or-how-do-i-identify-any-component/334129#334129 – Voltage Spike May 07 '22 at 06:07
0 Answers0
