Im trying to flash/debug a STM32H747XIH6 over J-link within STM32CubeIDE. One of the two cores, the CM7, flashes fine and i can enter the debugger. However when i try to flash the other core, the CM4, i get a popup with "Could Not Verify ST Device", and the console displays as shown below.
Any help or input is greatly appreciated!
The debug probe is trying to access memory (0x23000FD0) that is out-of-bounds.
Check your project/debugging toolchain configuration. You probably specified the wrong MCU.
Memory Map:
Source: STM32H747 Reference Manual
Velvel
  • 3,591
  • 30
  • Thank you for the input! But unfortunetly its the correct board, an STM32H747XIH6 which is what i selected when i created the project (which i have done twice with the same result), and the other cpu flashes correctly. And i have tried to find what is at 0x23000FD0 but i can find nothing more specific that the image you sent. – Caspar Westerberg May 05 '22 at 13:15
  • Check if your toolchain is up-to-date. I've had issues in the past with erroneous toolchain configurations. – Velvel May 05 '22 at 13:38
  • Another thing to check: setup a new minimal project (something like `void main() { return 0; }`) and see if this works. Maybe some not-so-obvious project option is broken. – Velvel May 05 '22 at 13:41
  • How can i check my toolchain? I have done "check for updates" and found none. And this that i am trying now is a minimal project. – Caspar Westerberg May 05 '22 at 14:10
  • "Check for updates" usually should do the job. – Velvel May 05 '22 at 14:39
