I am designing a custom board with a ATmega16u2. In the specifications of the linear voltage regulator, a 10uF capacitor is required between the regulated voltage and ground. A 1uF is required between the power and ground for the ATmega16u2, and a 100nF is required between the BMP388 power and ground. Do I use the highest value capacitor, or do I use all 3 capacitors in the circuit.
Asked
Active
Viewed 57 times
Which regulator? And how are the devices connected? What types of caps being used? The answer will also depend on how far apart the devices are on a PCB. – Justme May 05 '22 at 10:10
Also related/useful: https://electronics.stackexchange.com/q/400683/2028 – JYelton May 05 '22 at 20:10
