I am building a thermometer for a cryostat which operates at low temperatures (until 4 kelvin).
I would like to know the temperature of some parts in my cryostat during the cooling (so from 300 K to 4 K). The idea is to send a small current (in order not to heat the cryostat too much) in a resistive material which would get a higher resistance for low temperatures, and from the resistance measurement I could get a value for the temperature.
For a maximal precision I would need a material for which the resistivity changes a lot in this temperature range. Which material and which type of resistor (or even diodes, transistors, capacitors, etc.) would you suggest for this application?
For now I tried a thick film Ruthenium oxide resistor because this material seems to be used in some cryogenic temperature sensors, but it only goes from 10 kΩ to 10.4 kΩ when changing its temperature from 300 K to 77 K (liquid nitrogen) which doesn't seem to be enough change in resistivity.
I would be thankful for any advice.
