The GPD2846A module has a built-in amplifier into it. However, I want to use it with my headphones which don't require 1-2W (they are definitely going to distort sound and possibly be damaged). So I thought I could just solder the DAC-L, DAC-R pins (audio Left and Right output pins) and GND to a headphone jack and call it a day.
My concern is whether the amplifier wastes the 1-2W of power it normally would with a speaker connected (small form factor is desired so the battery is small and every mAh counts) even if there is nothing connected to it. I suppose if yes, I'll need to un-solder it from the board but I'd like to keep it there for future improvements so have that in mind too when answering please :)
  • There's more than one way to design an amplifier, and some designs can be _much_ more efficient than certain other designs. That module is so cheap, why not buy a few of them to play with, and measure the power consumption yourself? – Solomon Slow May 02 '22 at 16:15
"Does it consume any power": Yes.
"Does it consume the 1-2 W it would with a speaker connected": No.
It'll pull a tiny bit of power, though it's impossible to know how much without the datasheet for the amplifier. It won't consume significant amounts of power unless it's actually driving an output.
I doubt connecting your headphones directly to the DAC output will work very well, by the way. Couldn't say for yours in particular, but DACs aren't usually designed to drive a load directly.
Hearth
  • 27,177
  • 51
  • 115
