I am currently using a NUCLEO-WL55JC board. However, I could not initialize the logic analyzer because of the error "Trace: No Synchronization". I am programming it as single-core (Cortex M4 mode).
The watch tab works well, but the analyzer window seems to be not working. And, I have an error at the bottom showing "Trace: No Synchronization". I set the core frequency (4 MHz) as the same as the board's frequency (4 MHz).
What is your advice? By the way, I have a physical logic analyzer device at home and can use it instead of the virtual one if possible. Please let me know.
What I tried so far:
- Enabled DEBUG in CubeMx as "SerialWire" and "Trace Asynchronous Sw"
- Set on Solder Bridge 8 on the board (the manual advises it to enable SWO)
- Set different core frequency and keil debug frequency
- Using an external ST-LINK device
