The 2-stories house is equipped with a coaxial cable that has wall plugs in 1st and 2nd floors (it's also connected to the antenna on the roof).
Our IAP installed a modem for Internet (Arris CM820C) which frequency ranges are, according to the manual
- RF downstream: 108-1002 MHz
- RF upstream: 5-65 MHz
The modem is on the 1st floor.
Wifi is not powerful enough to reach the 2nd floor from the 1st, and a PLC test was not fully satisfactory.
So the next device "on trial" is a MoCA 2.5 Network Adapter for Ethernet Over Coax (Hitron).
- The "TV" plug would be for the modem
- the other one goes to the wall (first floor)
- then the other Hitron device would be connected to the 2nd floor coax socket, delivering Internet from the 1st floor.
The frequency range is 1175 to 1625 MHz according to the MoCA 2.5 specs page 12 (2.1.4 MoCA 2.5 Extended Band D Frequency Plan), range divided into several channels.
Based on that,
- is there a risk of interference between the IAP modem and the MoCA 2.5 Hitron?
- is there a channel to choose preferably on the Hitron?
(Not sure it is possible to change the IAP modem channel)
