As far as I know, potential difference (voltage), that's mean it needs two point to measure it.
Then what does vc or ve only or vb only?
If vce means potential between vc and ve? And what does ve only means or vc only means?
From this website: -
Double letters (cc) refer to power supply voltages. For example, Vee refers to the "emitter" voltage. In CMOS logic, Vss refers to the "source" voltage, and Vdd is the "drain" voltage.
Single letters refer to the voltage relative to ground; for example, Vc is the "collector" voltage relative to ground. Two different letters indicate the voltage between two terminals; for example: Vbe is the "base" to "emitter" voltage drop, while Vce is the "collector" to "emitter" voltage.
I mean, I could have used my own words but the website puts it succinctly.
When in doubt , Gnd is always the reference which by definition is always = 0V. (for a reasonable bandwidth) the suffix or subscript after V are:
CC = collector V+
EE = Emitter V-
DD= Drain for CMOS IC V+
SS= Source for CMOS IC V-
When given as Vbe, Vce or Vgs, Vds, it is assumed to be a differential voltage.
It could depend on the context but generally Vce is Vc - Ve, Vc is Vc - 0 (referenced to 0V), and Ve is the same.
