I accidentally discharge my lithium cell to 0.45V. Is is okay if I try to revive it by charging with 10mA of current till it reaches 2.5V?
cell capacity is 4000mAh.
You can try to revive it, but it won’t actually be revived even if it pretends to. You may get a “functioning” energy storage cell out of it, but whether the cell will release this energy through the terminals, or via a bursting wall and a bunch of concentrated heat – hard to tell.
You’ll end up with a fire starter just itching to go off, with all the dangers to life and property it brings on.
Some people would just say “hey, it’s a calculated risk”. But: have they done the calculation, or are they just hoping they’ll get lucky this once…
Throw it away. It's a huge safety risk.
Deep discharges that bring LiIon cells under about 2.5V cause irreparable damages to its internal structure.
See this document: https://www.analog.com/media/en/technical-documentation/lt-journal-article/LTMag_V18N3_Sep08.pdf. At page 9 you find this excerpt (emphasis mine):
Avoid very deep discharges below 2V or 2.5V, as this quickly and permanently damages a Li-ion battery. Internal metal plating can occur causing a short circuit making the battery unusable and unsafe. Most Li-ion batteries have electronic circuitry within the battery pack that opens the battery connection if the battery voltage is less than 2.5V, exceeds 4.3V or if the battery current when charging or discharging exceeds a predeined threshold
Another interesting reference on the subject is this: https://www.nature.com/articles/srep30248.pdf
Short answer: NO.
Longer answer:
Provided the cell is of a descent quality - AND - you have a fireproof place to experiment (a concrete or tiled floor and walls), you can try.
If the cell wakes up, it will be no more dangerous than before.
It will probably not wake up anyway.
Be sure to turn the charging on and then off from a distance of at least 3 meters (10 feet). Safety goggles highly advisable.
