Does anyone recognize this female socket pin layout as a standard design of any kind?
I was looking at 5-pin CB Radio Microphone sockets, and they are similar, but not the same layout.
Also, the ones I saw did not have the "sixth" connector pin in the middle hole. Does that make this a 6 pin socket?
If it helps, these are vintage sockets most likely 1980s or earlier.
    Looks like it *might* be a DIN connector. The thing with DINs is that they are often offered in varying circular arrangements of the pins - this might be a variant of the 240deg 5-pin DIN. I cannot locate one with that large center pin ( is it a chassis ground?) – mike65535 Apr 01 '22 at 20:25
  • looks like a std DIN-5 for MIDI but has +1 – Tony Stewart EE75 Apr 01 '22 at 20:32
  • looks like some sort ofvariant of 240-degree 6 pin DIN with pin 6 replaced with some sort of coaxial connector also these seems for be some sort of added locking lugs or thread. – Jasen Слава Україні Apr 02 '22 at 00:08
It's a 5-pin microphone connector.
There is no central pin. That's a chassis-ground lug in the centre, attached to the connector body, to which the shields are to be connected.
They are still being manufactured.
Please search for '61HA5FX Connector'.
vu2nan
  • 15,929
  • 42
It's a bog-standard DIN connector. The thing in the middle is a rivet, not a pin. I suggest replacing it with something saner though. Any modern circular connector would perform better. Those DIN connector had one benefit: cheap and fairly low precision needed to make them, compared even to the venerable D-Sub connectors. Outside of extremely cost constrained consumer applications, I wouldn't use one. Much better connectors don't cost all that much more.
