I want to use TL494 IC for voltage regulation. For this, I am giving a 2.5 V reference to the inverting pin of the error amplifier and wants to vary a voltage from 0- 5V at the non inverting terminal through potentiometer. And having a gain of 100 through the resistance of 51 kohm and 510 ohm. But when I'm varying the voltage at pin1 that is non inverting terminal, I'm obtaining a pulse signal only for a second and then it's becoming a constant voltage at the output. What could be the issue?
Asked
Active
Viewed 188 times
Russell McMahon
- 147,325
- 18
- 210
- 386
ashu_09
- 37
- 2
2The TI datasheet has a test circuit. Try that. If it doesn’t work, then maybe you have a dud chip or some more fundamental problem like a broken wire. – Kartman Mar 31 '22 at 08:15
Diagram at a minimum must be properly oriented. – Russell McMahon Apr 15 '22 at 12:26
