I have an HVAC system with a powered open/powered closed supply damper, Ultra-aire 120 V dehumidifier and ventilation damper that is powered to open. I have everything wired up and it is working, however, since I have two 24 V signals going to open the powered supply damper they backfeed each others circuits when they are supposed to operate independently. Since they are wired together they turn each other on.
What do I need to do to isolate two 24 VAC inputs to one 24 VAC output? Both inputs need to operate independently at not complete each other’s circuit. Everything is AC current. I think diodes would fix issue if this was DC. Maybe some special relay?
The supply damper needs to be powered to close and open. So, our initial relay would apply power to open when both or either of them have voltage. I will need to also apply 24 VAC to the power close, but only when both of the other inputs are off. If one or both of the SW1 or SW2 have power, power to the powered close turns off. What would be the configuration for this scenario?
I’m at a loss. I’m no expert when it comes to this.
