I've been attempting to use SERCOM2 SPI Master on the SAMD21G18J but have been unsuccessful. I tried the configurations with SERCOM0 and SERCOM4, and they both worked. The most intriguing behavior is that when I initialize the SERCOM2 SPI, all of the other I/O pins stop working as well. The clock is not generated, and CS is not operational.
I tried several bootloaders, but the results were the same. To begin, I used the bootloader of an Arduino Nano IOT 33, which uses the same chip, in order to use the Arduino IDE more easily.
Then, I tested with the bootloaders Arduino Zero and Adafruit M0 bootloader. The idea of testing other bootloaders was because the Arduino Nano IOT 33 uses SPI SERCOM2 to communicate with its WIFI module, and could be protected somehow. Any insight will be useful.
The schematic is displayed below: schematic
The SERCOM2 Pads: SERCOM
Main routine:
// include the SPI library:
#include <SPI.h>
#include "SercomSPISlave.h"
SercomSPIMaster Spi2;
void setup() {
  PORT->Group[PORTA].DIR.reg |= PORT_PA08; // Output set wifi ctrl
  PORT->Group[PORTA].OUT.reg &= ~PORT_PA08;  // Turn OFF wifi
  // PORT->Group[PORTA].OUTCLR.reg |= PORT_PA08;
  PORT->Group[PORTA].DIR.reg |= PORT_PA04;  // set output Group; Turn-On Circuit;
  PORT->Group[PORTA].OUT.reg |= PORT_PA04;
  PORT->Group[PORTA].OUTSET.reg |= PORT_PA04; // Turn ON
  PORT->Group[PORTA].DIR.reg |= PORT_PA14;  // set CS output
  pinMode(4, OUTPUT);
  // set the slaveSelectPin as an output:
  pinMode (slaveSelectPin, OUTPUT); //spi1
  // initialize SPI:
  Spi2.Sercom2Masterinit(); //spi2
void loop() {
  char c = 'z', r;
  PORT->Group[PORTA].OUT.reg &= ~PORT_PA14;  // Turn OFF wifi
  delay(100);
  // send in the address and value via SPI:
  r = Spi2.transfer2(c); //spi1
  Serial.println(r);
  delay(100);
  // take the SS pin high to de-select the chip:
  PORT->Group[PORTA].OUTSET.reg |= PORT_PA14; // Turn ON; unset pin
  //delay(1000);
Header file:
     while (GCLK->STATUS.reg & GCLK_STATUS_SYNCBUSY); //Wait for synchronisation
  //Set up SPI Control A Register
  SERCOM2->SPI.CTRLA.bit.DORD = 0; //MSB first
  SERCOM2->SPI.CTRLA.bit.CPOL = 0; //SCK is low when idle, leading edge is rising edge
  SERCOM2->SPI.CTRLA.bit.CPHA = 0; //data sampled on leading sck edge and changed on a trailing sck edge
  SERCOM2->SPI.CTRLA.bit.FORM = 0x0; //Frame format = SPI
  // Choose PAD configuration
  SERCOM1->SPI.CTRLA.bit.DIPO = 0x1; //DATA PAD1 MISO is used as Master input (slave mode) // page 492
  SERCOM1->SPI.CTRLA.bit.DOPO = 0x3; //DATA PAD0 MOSI is used as Master output and PAD3 as SCK
  SERCOM2->SPI.CTRLA.bit.MODE = 0x3; //SPI in Master mode
  SERCOM2->SPI.CTRLA.bit.IBON = 0x1; //Buffer Overflow notification
  SERCOM2->SPI.CTRLA.bit.RUNSTDBY = 1; //wake on receiver complete
  //Set up SPI control B register
  SERCOM2->SPI.CTRLB.bit.RXEN = 0x1; //Enable Receiver
  //SERCOM2->SPI.CTRLB.bit.SSDE = 0x1; //Slave Selecte Detection Enabled
  SERCOM2->SPI.CTRLB.bit.CHSIZE = 0; //character size 8 Bit
  //SERCOM1->SPI.CTRLB.bit.PLOADEN = 0x1; //Enable Preload Data Register
  //while (SERCOM1->SPI.SYNCBUSY.bit.CTRLB);
  //Set Baud rate
  uint16_t BAUD_REG = ((float)SPI_CLK_FREQ / (float)(2 * SPI_BAUD)) - 1;  //Calculate BAUD value For Sync
  SERCOM2->SPI.BAUD.reg = SERCOM_SPI_BAUD_BAUD(BAUD_REG);       //Set the SPI baud rate
  SERCOM2->SPI.CTRLA.reg |= SERCOM_SPI_CTRLA_ENABLE;         //Enable the Sercom SPI
  while (SERCOM2->SPI.SYNCBUSY.bit.ENABLE);
  //Enable SPI
  SERCOM2->SPI.CTRLA.bit.ENABLE = 1;
  SERCOM2->SPI.CTRLB.bit.RXEN = 0x1; //Enable Receiver, this is done here due to errate issue
  while (SERCOM2->SPI.SYNCBUSY.bit.CTRLB); //wait until receiver is enabled
uint8_t SercomSPIMaster::transfer2(uint8_t data) {
  while(SERCOM2->SPI.INTFLAG.bit.DRE == 0);
  SERCOM2->SPI.DATA.reg = data;
  while(SERCOM2->SPI.INTFLAG.bit.RXC == 0);
  return (uint8_t)SERCOM2->SPI.DATA.reg;
ocrdu
  • 8,705
  • 30
  • 42
bmalbusca
  • 197
  • with Arduino sercom2 on Nano IoT is configured as SPI1 and SPI1 is connected to the on-board Nina WiFi module – Juraj Feb 17 '22 at 06:04
  • Yes, on Arduino IOT 33 the SERCOM2 is used to connect NINA-W102. But I tested then the Adafruit M0 bootloader which doesn´t have any thing connected to SERCOM2 and didn´t worked also. Note, I referred Arduino IOT but this is a custom board with SAMD21G18 @Juraj – bmalbusca Feb 17 '22 at 10:52
A partial answer to your question why your code is not working is that you use SERCOM1 to choose the PAD configuration. Instead, you shall use SERCOM2 there as well.
Additionally, you might encounter issues with using SERCOM2 with the Adafruit M0 bootloader, as some of these pins are already used for the Hardware Serial UART. Please see the considerations in Adafruit Muxing it up SERCOM2.
I suggest you start debugging by setting up a SERCOM2 SPI slave using the latest version of the SercomSPISlave Arduino library and flashing this to an Arduino or Adafruit SAMD21 board. This code is similar to your header file. After successfully setting up a slave, you can change the registry settings to change the slave into a master, by changing the registry settings in the function SercomRegistryInit. Afterwards you can try to flash the code to your board and see if you encounter any issues with your specific hardware.
Note: I am the author of the SercomSPISlave Arduino library. This repository is created and maintained without affiliation to a company or product.
lenvm
