This was one of the questions for the repetition paper before the test. "A lit light bulb has a resistance of 1320 Ω. It uses tungsten as a filament, and when hot, has a resistivity of 0.92 µΩm. Assume the filament is 2.0 cm long, how thick is then the filament?"
I work it out as follows: Using the formula for resistance in conductors:
  • ρ = Resistivity
  • l = length
  • A = cross section area
  • R = resistance
    1. R = ρl/A
    2. A = ρl/R
    3. A = 0.92 µΩm * 0.02m / 1320 Ω
    4. A = 1.39×10^-11 m^2
    5. A ~= 13.9pm^2
That's just ridiculous. The answer given by my professor is 4.2µm^2. What am I doing wrong here?
placeholder
  • 29,982
  • 63
  • 110
Peatherfed
  • 163
4.2 microns, not 4.2 microns squared. Area is not a unit of thickness. Divide your answer by pi, take the square root, and multiply by 2 to yield diameter
Scott Seidman
  • 29,274
  • 44
  • 109
1000 mm = 1 meter & 1,000,000 mm^2 = 1 m^2
$$ A = 1.39 x10^{-11} m^2 = 1.39 x10^{-5} mm^2 $$
Assume the filament is circular wire...
$$ A = \pi r^2 $$ $$ r = \sqrt{1.39x10^{-5} / \pi} = \sqrt{4.44x10^{-6}} = 0.002106 mm $$
Double the radius to get the diameter (thickness): 0.004213 mm = 4.213 microns.
Blup1980
  • 6,120
  • 26
  • 47
Alan Campbell
  • 1,019
