Hello all and thank you in advance for taking a look at my problem.
I have made a circuit which takes a differential voltage from a Wheatstone bridge (pressure transducer) and converts to an analog voltage to be read by an ADC.
Overall Circuit
The first stage of the amplifier takes the differential input and outputs at unity gain. Pin1 of IC4G1 is outputting ~.2 volts with no pressure applied to the transducer. I think the output of the first stage should equal the voltage measured across the output of the transducer.
On the pressure transducer, IC2, the voltage Vpin4-Vpin2 = -5mV. After cutting the traces going to the op amp, that same measurement yields 0V (as I would expect with zero pressure on the transducer.)
The second stage of the op amp should have a 100x gain but behaves like it has around 50x gain.
Here is a screenshot of our layout. Layout2
Hopefully there is something simple we're missing.
If there is any information I've missed let me know and I'll get it posted ASAP. We're in a bit of a crunch to get this solved.
  • What voltages are you using for the op amp power supplies? The LM358 is not a rail-to-rail op amp, so it is not a great choice for single-rail applications. – Elliot Alderson Feb 14 '22 at 23:44
  • Yup. If you want to use old cheap "jelly bean" op-amps in single-supply circuits, the LM324 is way better. You still have to be careful with it, because the input and output can go to the negative rail, but not the positive rail. – TimWescott Feb 15 '22 at 00:04
    @TimWescott The LM358 is just half an LM324. They're both single-supply op-amps. Maybe you're thinking of the 4558, popular for audio, which is more of a dual 741. – Spehro Pefhany Feb 15 '22 at 00:07
  • @SpehroPefhany dang, you're right (as usual). It's been a while -- that's what I'd remembered, but I wasn't sure so I double-checked. Two different data sheets, two different companies, two different sets of numbers... In my (lame) defense, these days, if the application calls for a rail to rail amplifier, I just find a rail to rail amplifier and design it in. – TimWescott Feb 15 '22 at 14:58
Your differential amplifier is loading the bridge- the differential input impedance is not very high. The effect will depend on your bridge resistors and may have a temperature coefficient.
At least as important, you have a single supply, so the accuracy is going to peter out close to 0V (differential) input. The output of the first op-amp cannot go down to 0V, and especially not when it's trying to sink all that current through R74+R75 (if 2.5V is the nominal CM voltage that will be about 62uA so the 50uA sink inside the LM358 will likely be overwhelmed). Above 1V out it should be accurate. At 200mV, let alone 5mV or zero, nah. This is true of any op-amp including rail-to-rail, by the way. They don't work all the way to the rails. The LM358 is not quite as good as some more modern chips, but it does illustrate the problem well.
You would do better with an instrumentation amplifier (which does not load the bridge significantly) and a bipolar supply (which allows internal nodes to actually reach 0V). If you have some kind of special situation you might be able to use a single supply, but that depends on unstated details.
Edit: Here is a rough design that will work with any rail-to-rail or single supply op-amp that can handle 20V and avoids both the above design flaws, even with a single supply. The output is G*Vin(diff) + Vbias. In this case, G = 201 and Vbias = 2.0V
You could also lower the supply voltage, subject to possible op-amp limitations, which might help protect the ADC.
Spehro Pefhany
  • 376,485
  • 842
  • Thank you very much for the detailed response. Would the Texas Instruments TLV2316IDGKR be a good option? It seems to have the characteristics we need like rail to rail input swings. – Ryan Coleman Feb 15 '22 at 00:12
    Sorry, but you cannot fix this by substituting another chip. There are two fundamental flaws in the design. I will draw something up that will work, using the LM358. The TLV2316 will explode if you try to power it from 20V. – Spehro Pefhany Feb 15 '22 at 00:28
  • We also have a 5V supply nearby on the board and the output of the pressure transducer is nowhere near 5V. Would that make the TLV2316 somewhat acceptable? – Ryan Coleman Feb 15 '22 at 00:39
    Why don't you simulate it and see why it won't work near 0V? And the loading issue remains. – Spehro Pefhany Feb 15 '22 at 00:40
  • We're going to give that a try in LT Spice. Thank you very much. I have another post for a similar but different problem on this board. If you have to a chance to take a look we'd appreciate it greatly. – Ryan Coleman Feb 15 '22 at 01:27
  • I don't buy "loading it differently on each input". Pin 4 of the transducer sees 40k to ground, and pin 2 sees 20k to half the voltage on pin 2 (if the op-amp is ideal and can balance). So in effect there is the same current in 2 and 4 when the bridge is balanced. Plus the bridge has like 2k output impedance, low compared to 40k. Thus I believe the 5mv observed is due to op amp input offset, rated 3mv typ, 7 mv max @5V, perhaps growing with the power supply. – fgrieu Feb 15 '22 at 15:19
  • @fgrieu I think you're right, the loading is when it's off balance. I'll edit that. The output cannot reliably swing to 5mV of the negative rail though, nor 50mV, and barely 500mV when sinking current so it's important not to drive the input amplifier output near ground. The input offset would be a consideration if OP had bipolar supplies, but he doesn't. A better op-amp would certainly help with that. – Spehro Pefhany Feb 15 '22 at 15:26
    Ah, I now get your point that the op-amp can't balance for low pressure, because the output would need to go to ground, and there's a VCESAT in the output. That would also be a (possibly better) explanation of the -5mv. It's consistent with the observed sign. – fgrieu Feb 15 '22 at 15:52
The primary problem with this design is a lack of specs for gain and offset error with accuracy on each and a calibration test.
If you had done this exercise you should observe the following design flaws ;
  1. Gain error.
  • If your gain error tolerance is <1% then your load should be > 100x the source R. Reading Honeywell specs the source impedance (output) is between 2k and 10k. Your Differential Amplifier bridge input impedance is 2R on each input = 40K and a differential impedance of 2R=40K. This results in an unnacceptable gain error <20%.
  • Correct by using Zin >= 1M such as an INA with Rail to Rail output and variable gain =100
  1. Offset error
  • due to lack of dynamic range of Op Amp Bipolar types are not rail to rail
  • You ought to also have a null pressure spec and tolerance error . Determine what the worst case null pressure input offset is and consider if that is acceptable or add a calibrated Offset to the Op Amp. in mV to be null out in software or with a pot.
Recommendation.
  • Start with design specs before design with error tolerances and environmental limits
  • verify initial design against specs , consider noise and filtering requirements
  • if meets specs, then do layout.
  • Choose a CMOS Instrument Amp (INA) with design specs for Gain, Offset tolerance over all environmental stress limits (Vdd, T'C, etc)
Other issue: 50x gain vs 100x ?? schematic is OK with Av=101. Component tolerances undefined. and unverified.
  • I presume pressure is unipolar, but that is also undefined in missing design spec
  • +1 for mentioning the offset of the LM324. It's specified 3mv typ, 7mv max. @5V, perhaps growing with power supply. The observed 5mv can be explained in this way. – fgrieu Feb 15 '22 at 15:22
