I'm a beginning hobbyist with a pregnant wife, which makes me nervous about lead. I have a breakout board that is RoHS-non-compliant, very likely containing leaded solder. How worried should I be about handling this board? Everything else I use is lead-free, and I don't plan on melting the solder in the breakout board, but I can't avoid touching the board, and touching other things thereafter. My wife and future child won't touch any of this directly, but they'll be exposed to any contaminations I miss when cleaning up.
All the information I could find on lead in electronics seem to talk about:
- The effects on the adult handling the material, not fetuses and infants around them.
- Tearing apart electronics for recycling, presumably creating leaded dust along the way, which I won't be doing.
- Lead leeching from landfills, which doesn't apply in my case.
- Finished products that don't expose the solder, which the breakout board is not.
- No research or data, just an "I've been doing this for years".
Is there any data / recommendations from a proper authority on the risks of just handling leaded solder without melting it, when there are small children around? Or is this situation just too niche for studies to be conducted?
(BTW: I'm aware of the dangers of flux, which tends to get mentioned in answers to questions like this. The solution there is simple, though: just ventilate. I'm more worried about lead because it doesn't readily disperse.)
