On the ATmega32U4 MCU there are several pins related to USB:
  • VBUS
  • D+
  • D-
  • UCAP
  • UGND
  • UVCC
In the datasheet and in almost all reference schematics I find on the Internet, it's explained how to connect those pins when you need the USB.
On my board, instead, I don't need the USB at all. Hence, I want to understand how to connect those pins.
I'm not sure if I can just leave them floating or else.
Mark
  • 1,161
The datasheet does have that information.
You can make a self-powered USB device as per the datasheet diagrams and imagine the USB cable is unplugged, which gives enough information how the pins should be connected without USB connection.
Justme
  • 127,425
  • 261
Grab a schematic that uses the USB interface like this: -
And ask yourself what connectivity is important if there isn't anything plugged into the USB connector. You'd end up with this: -
Schematic image taken from here.
So, should VBUS be connected to Vcc - you can always double check that in the data sheet and, is it any great hardship to make that connection anyway? What about UVCC and UGND - well, is it really any problem to connect them to Vcc and GND
  • It's not a problem. But I'm trying to understand, not to guess... For example, the capacitor on UCAP may be mandatory because it's the output of the internal regulator. I cannot know if omitting it may lead to some issues. – Mark Feb 07 '22 at 14:45
    @Mark then you should thoroughly read the data sheet from front to back and double check everything. – Andy aka Feb 07 '22 at 14:50
