I have used a voltage follower with a TSH082. I was able to get a half-wave signal with some slight ringing on the output (shown below).
Is there a way to reduce the ringing on the half-wave signal output?
Single Supply Voltage follower
enter image description here Signal Measurement
Single Supply inverting amplifier:
I have used a precision rectifier, and I unable to get a half wave signal.
Using a single supply precision half wave rectifier: enter image description here
Null
  • 7,448
Sam
  • 319
  • Does your circuit use a bypass capacitor on the power supply? – qrk Jan 31 '22 at 23:35
  • @qrk it has a bypass capacitor of 0.1uF between the +5V to GND. – Sam Feb 01 '22 at 00:09
    What is your system objective - rectification at high speed is difficult. Are you intending to get amplitude? Or is it specially for wave-shaping? There may be other ways to achieve your objective. – Kevin White Feb 01 '22 at 00:41
  • @KevinWhite I want to get a half wave signal of the input. – Sam Feb 01 '22 at 00:43
    @Sam - yes, but why? What is the system objective. Maybe that is achievable without getting the half-wave rectified version. It is rare to need a half-wave rectified signal. Are you trying to get the average amplitude of the signal for example? – Kevin White Feb 01 '22 at 01:17
  • @Sam - do you mean the instantaneous amplitude or the average amplitude? Are you going to filter the signal after the rectification then compare? – Kevin White Feb 01 '22 at 02:46
  • @KevinWhite the main reason: I have two branches, where one branch is constant amplitude sine wave and the other branch is varying. When I do differential of two branch, the moment the varying branch amplitude is lower than the other constant amplitude branch, the output signal inverts which I don't want. Therefore, the idea is to only take the halfwave signal of both branches, and do differential. Hope this makes sense. – Sam Feb 01 '22 at 03:06
  • @KevinWhite i think its instantaneous amplitude; just to be sure, its given Voltage peak at that moment. – Sam Feb 01 '22 at 03:31
  • @Sam - what is supposed to happen on the negative half-cycle? – Kevin White Feb 01 '22 at 09:32
  • It doesn't seem like you need a rectifier at all - just a comparator and multiplexer. – Kevin White Feb 01 '22 at 15:33
  • @KevinWhite can I possible talk to you virtually. In differential amplifier, when the branch with constant amplitude is higher than the varying branch, the output of the differential branch inverts; I want to avoid that. I only want an output when the varying amplitude branch is higher than the constant amplitude branch. – Sam Feb 01 '22 at 17:00
  • Let us [continue this discussion in chat](https://chat.stackexchange.com/rooms/133715/discussion-between-kevin-white-and-sam). – Kevin White Feb 01 '22 at 18:26
It looks like you are driving the outputs to create a half-wave rectification in an unstable manner.
This Op Amp has GBW = 100 MHz with 40 deg phase margin when loaded with 150 ohms// 30 pF yet your results are different.
Assertion: This design is a poor method of rectification for high speed.
This is what happens when the output saturates and the input is no longer a virtual ground or an error amplifier with a null input operating in the linear region. Effectively the gain is always 0 when the output is saturated then the input approaches the null input and the non-linear gain goes to near 80 dB of linear gain open loop with unity gain closed loop.
  • Diode saturation capacitance and reverse recovery time also influence the results and thus keeping C in the low pF and reducing R without current limiting will help.
Essentially the Op Amp has less phase margin coming out of saturation.
Recommendation:
  • Use a bipolar supply or bias the output to keep the inputs & outputs active in the linear range. (see schematic below)
  • use an analog switch and comparator to rectify the signal.
  • try a suitable pull-up resistor on the output to pre-bias the output current.
  • try a 150 ohm load to dampen the response of the high side driver
and YET another Design enter image description here
  • I want to let you know that I have tried the above circuit design before but it did not work out. is there a specific type of diode that we need to use for precision half wave rectifier? I will try the circuit again with TSH82, and post the result. Thank you – Sam Feb 01 '22 at 00:21
  • The lowest capacitance small signal diodes and check impedance ratio at slew rate – Tony Stewart EE75 Feb 01 '22 at 00:31
  • I have tried both the circuitry, and I am unable to get half wave rectifier; I have uploaded the signal in the post, and added few more info. I can get a half wave signal using a non-inverting amplifier or inverting amplifier with slight ringing; would that help with stability. – Sam Feb 01 '22 at 03:04
