Can someone give me the capacity (in Ah) for this battery?
Asked
Active
Viewed 61 times
JRE
- 67,678
- 8
- 104
- 179
1[This](https://panda-bg.com/datasheet/1622-360803-Battery-GP-ULTRA-ALKALINE-23AE-12V.pdf) may be the datasheet. Just read it. The packaging is mostly just a lot of "buy me hype." (No added lead mostly means nothing. Their suppliers may do all that nasty work, if needed. And the 0% mercury just means it is less than 0.5%, at least in the US packaging rules I'm vaguely aware of. They aren't advertising the meat. They are selling the sizzle.) Compare it with some other competing devices that also have datasheets. And even then, you probably have no recourse if the device doesn't do what they say. – jonk Jan 30 '22 at 04:09
Thanks you Jonk. – Sreenandan Balasubramaniam Jan 30 '22 at 04:35
1Be aware that the ratings include a voltage that almost immediately drops from 12 V down to 6 V before they consider the battery "dead." Whatever you use them for, make sure that the device works well with them over such a wide voltage range. These batteries are basically about 9 V and they cannot stand much of a load unless you want them to get used up pretty fast. The capacity drops to < 50% of the rating, under high load. – jonk Jan 30 '22 at 04:40
Ok, got it. Thank you. – Sreenandan Balasubramaniam Jan 30 '22 at 05:09
1I hope you aren't expecting this battery to power the solenoid in your other question. – Jan 30 '22 at 13:34
