I'd like to execute a virtual sequence's task as below:
class MYTest extends uvm_test;
my_base_ahb_vseq_c my_base_ahb_vseq;
`uvm_component_utils_begin(MYTest)
`uvm_component_utils_end
function new(string name = "MYTest",uvm_component parent);
super.new(name,parent);
endfunction : new
virtual function void build_phase(uvm_phase phase);
super.build_phase(phase);
my_base_ahb_vseq = my_base_ahb_vseq_c::type_id::create("my_base_ahb_vseq", this);
endfunction : build_phase
virtual function void end_of_elaboration_phase(uvm_phase phase);
uvm_root uvm_top = uvm_root::get();
super.end_of_elaboration_phase(phase);
`uvm_info(get_type_name(), $sformatf("MYTest!!! \n %0s", uvm_top.sprint()), UVM_LOW)
endfunction
task run_phase(uvm_phase phase);
phase.raise_objection(this);
`uvm_info(get_type_name(), "My AHB Test Start!!", UVM_LOW)
my_base_ahb_vseq.do_write(8'h12, 8'h34);
phase.drop_objection(this);
endtask
I implemented the virtual sequence as below:
class my_base_ahb_vseq_c extends AhbUvmUserVirtualSeq;
myAhbTransaction trans;
`uvm_object_utils_begin(my_base_ahb_vseq_c)
`uvm_field_object(trans, UVM_ALL_ON)
`uvm_object_utils_end
function new(string name="my_base_ahb_vseq_c");
super.new(name);
endfunction // new
endclass
When I execute MYTest
, I got the error message below:
xmsim: *E,TRNULLID: NULL pointer dereference.
File: VirtualSeqLib.sv, line = 258, pos = 13
Scope: pstest.my_base_ahb_vseq_c@3148_1.do_write
Time: 0 FS + 33
Verilog Stack Trace:
0: task pstest.my_base_ahb_vseq_c@3148_1.do_write at ../VirtualSeqLib.sv:258
1: task pstest.MYTest@3049_1.run_phase at ../UserTest.sv:37
How do I execute the virtual sequence's task in the test class correctly?
