I want to switch a ballast with a relay. The target lamp is rated at 120 W, but the (electronic) ballast states a 55 A inrush current. Does this mean that as soon as the relay is closed, 55 A will be passing through the relay contact?
What kind of relay would I need for such a task and what ratings should it have? Is a normal 5 VDC relay rated at 250 VAC/10 A enough for this?
Here is the relay I want to use: Omron G5LE
