I am trying to silence my air purifier (Philips AC5659/10). I think it uses a piezo-buzzer (front & back of PCB visible on page 4 of this document). In a similar vein to this question, I would like to know if it's safe to just remove the disc, leaving the inside of the buzzer disconnected?
Asked
Active
Viewed 281 times
it's safe if you don't break it. have you tried tape? – Tony Stewart EE75 Jan 08 '22 at 22:53
I have tried tape and putting some silicone, but it's barely muffled. So I am verifying if it's OK for this circuit to just remove the internal disc without replacing it with anything. – Karol J. Piczak Jan 08 '22 at 22:56
Most probably yes. – winny Jan 08 '22 at 23:17
It is redundant – Tony Stewart EE75 Jan 09 '22 at 00:28
Take a plastic cap of a bottle and glue it over it. – Codebeat Jan 09 '22 at 23:51
I did this with my toaster oven because it was ear splitting loud. Unplug the device, take a flat head screw driver just pry it a bit at the bottom of the black cylinder. If it's anything like my piezo was, and they look very similar, it's a plastic cylindrical cap on top of a plastic tube base that houses a piezo disc inside. The cap popped right of and I took the disc out essentially leaving an open circuit in its place. Wasn't even glued in place.
DKNguyen
- 54,733
- 4
- 67
- 153
That's exactly what I did. I've removed the piezo disc. I am only contemplating if leaving an open circuit there could have some residual effects. From what I get from this question: https://electronics.stackexchange.com/questions/297304/how-can-removing-a-piezoelectric-speaker-buzzer-damage-a-circuit this could be an issue with transformers, but I don't think that's the case with this PCB. However, my electronics knowledge is fairly limited, so I am looking for some confirmation from experts in this area. – Karol J. Piczak Jan 09 '22 at 01:04
2@KarolJ.Piczak It's fine. Designers usually aren't spiteful enough with deep enough pockets to put in circuitry to detect whether the piezo is open/functional or not to disable the entire device. – DKNguyen Jan 09 '22 at 01:04
I did not expect to find any specialized circuitry to detect this kind of tampering. I was more concerned with what potential physical side effects could happen assuming that this circuit wasn't designed for such a situation. But I've managed to strip the piezo disc, leaving it open as in the picture, and so far it seems to be working fine. – Karol J. Piczak Jan 09 '22 at 23:37
I can now add an empirical answer to this - I've removed the piezo disc, and everything seems to be working fine so far, totally silenced.
Karol J. Piczak
- 131
- 1
- 1
- 5
