I'm trying to program a R7F0E01182DNG#AA0 MCU, using the serial programming feature. It's not working, so as part of troubleshooting I'm paring my design down to the minimum functional circuit. This is what I have:
minimal schematic
Can someone familiar with these chips tell me if it looks correct?
Power is supplied from a bench PSU, and the programmer is a 3.3v USB to serial adapter. The DTS line on the serial adaper is used as a reset signal and I confirmed that that is working with a logic analyzer.
Secondary question: if I wanted to program it using SWD, which pins are those? I can't find it in the datasheet or manual.
Edit:
I determined the SWD pins. SWCLK is TXD9 (P411). SWDIO is RXD9 (P207).
I also obtained an official programmer, the e2 lite. And it still does not work.. When I use that I get the error message "Error 0x00040102: Not connected to the user system." And I checked with an logic analyzer and it's not toggling any pins before the error occurs... ugh
Drew
  • 6,370
  • Normally microcontrollers have a cap on the reset pin and they are quite picky with the value chosen. Is this not the case here? What does the datasheet say? – Lundin Jan 04 '22 at 08:54
  • @Lundin According to the hardware design guide (page 23), no cap is required. – Drew Jan 04 '22 at 09:08
  • Ok but regardless of that, exposing the reset pin to a connector and a long trace is somewhat naive. This is not a signal that you want to expose to EMI. So if the MCU doesn't want a cap there for reset timing purposes, then at least add some 47pF to 100pF for EMI reasons. – Lundin Jan 04 '22 at 09:11
  • @Lundin I'm just trying to get the chip to program, at all. I'm not really at that phase of the design yet. – Drew Jan 04 '22 at 21:30
  • I would probably drop this serial bootloader thing then and use SWD. You'll want SWD for debugging no matter. – Lundin Jan 05 '22 at 07:06
  • I was thinking that too. I was actually going to try the e2 lite programmer because it's officially supported and reasonably priced. Do you think I should go for a generic SWD programmer instead? I have a st link v2. – Drew Jan 05 '22 at 07:17
  • From what I hear ST link only works on ST. I'd recommend a Segger JLink, I'm using one for some 4-5 different Cortex M projects, all with different MCU vendors. Microchip, ST, NXP, Silabs... – Lundin Jan 05 '22 at 07:34
0 Answers0
