39
In my home, I have some halogen spot lights, which have an energy efficiency rating of 'C':
Osram halogen Decostar 51 standardGU5.3 bulbEnergy efficiency rating C
I would like to replace them with more efficient LED bulbs, but looking on the Philips website, they claim their bulbs are rated 'F'!
LEDspot VLE GU5.3 MR16 7W 830 36D
LEDspot VLE GU5.3 MR16 7W 830 24D
Why would a 50W bulb be rated better than a 7W equivalent?
Rocketmagnet
  • 26,933
  • 92
  • 177
    Note that the links to not point to the Philips website but to a retailer, and possibly not the most recent version of those bulbs. Similar (and more recent) bulbs on the Philips website do also have ratings of F or even G, though. – jcaron Jan 04 '22 at 11:59
EU energy ratings get re-done regularly; a rating indicates placement in the field of competitors at the time of rating.
Things that were A a couple years ago might now be G; hence, you need to evaluate things with comparable tests. Since new halogen reflector lamps haven't been into the market in the last decade, these ratings are simply outdated.
Energy label Standardized Energy label. Note (VII) needs to be the same for different labels to be comparable. The currently valid regulation, as per the consolidated regulation linked to below, is 2019/2015 (state of 2021-09-01)
As far as I could figure out quickly, the valid energy efficiency classes since 2019 are:
Energy efficiency class Total mains efficacy ηTM (lm/W)
A 210 ≤ ηTM
B 185 ≤ ηTM < 210
C 160 ≤ ηTM < 185
D 135 ≤ ηTM < 160
E 110 ≤ ηTM < 135
F 85 ≤ ηTM < 110
G ηTM < 85
And halogen incandescent lamps achieve of only up to 24 lm/W, so they can't be any better than G.
Source: EU Commission Delegated Regulation
2012rcampion
  • 592
Marcus Müller
  • 88,280
  • 131
  • 237
    Not quite sure where the downvote comes from, if the person downvoting could comment, I might improve my answer :) – Marcus Müller Jan 02 '22 at 22:08
    Upvote added - to balance AND deserved :-) – Russell McMahon Jan 03 '22 at 08:47
    Good answer. Don't worry about the odd downvote. Look at great YouTube videos, they get hundreds of thousands of +1s and always about 2% of that as -1s. There's a lot of weird folk on the internet, and accidental clicks and fat fingers. You can never please everyone. – Dan Sheppard Jan 03 '22 at 14:42
  • The comparison for A is the wrong way around – Douglas Leeder Jan 03 '22 at 22:03
    @DouglasLeeder Looks correct to me? Category A produces more than 210 lumen per watt. – gerrit Jan 04 '22 at 08:54
  • Well, on certain versions of iOS, the touch zone for DV is enormous, I used to DV all the time by mistake. Or they might be DVing the absurdity of the scheme, which only a Brussels bureaucrat could love. When they change the scale, they should change the chart title (thing above (I)) as well as the look/feel of the whole chart, so you don't have to read footnotes to know the difference. – Harper - Reinstate Monica Jan 04 '22 at 16:31
    Where can I even buy a 210 lm/watt light source!? – Kevin Kostlan Jan 05 '22 at 01:46
  • @KevinKostlan You can buy 206 lm/W low-pressure sodium-vapor lamps, and when you look at the regulation, there's bonuses (as in: single-percentage) for directivity. So a bulb assembly with such a lamp and a reflector might just get above that. Other than that, White-ish LEDs for horticulture around 200 lm/W are available right now, and if I remember talking to colleagues from photonic/light-technology institutes before, we have ways to make 300 lm/W LEDs, just not commercially. – Marcus Müller Jan 05 '22 at 10:23
    Note that it's pretty clever to regulate so that right now, it's hard to come into the top tier; otherwise, you'd not be offering a competitive advantage to innovate for efficacy. – Marcus Müller Jan 05 '22 at 10:24
  • _"And halogen incandescent lamps achieve of only up to 24 lm/W"_ — an incandescent bulb with hot mirror surface can achieve more. – Ruslan Jan 06 '22 at 00:01
40
The old ratings were designed for incandescents, so all the modern LED bulbs were getting absurd ratings like A+++, so they just changed the scale to make it harder to get the A rating. Basically C is the new A++. So you can't compare the old scale and the new scale.
Of course, this means the previous labels on your fixtures that said "do not use bulb below class C" no longer mean anything. But these labels were meant to prevent you from using incandescent bulbs in fixtures made of plastic that wouldn't tolerate the heat, and there are no more incandescent bulbs, so who cares.
The useful thing about this regulation is they made it mandatory to specify the light output in lumens. So you can look at how many lumens it outputs, look at the power, divide, and you get the efficacy in lumen/W.
Now you may ask, why is the efficacy in lumen/Watt not what is printed on the box instead of useless "ABC" ratings? Well, it's brought to you by the same bureaucrats that give my gas-guzzling V6 a better pollution rating than my high mpg diesel, lol.
Note luminous efficacy of LED lightbulbs is not relevant unless you have a very large number of them. If you upgrade a bulb from a 13lm/W 60W incandescent to a 100lm/W 8W LED, both output about 800 lumen, and you save 52 Watts, and it does add up. But if you upgrade that 100lm/W 8W LED to a 200lm/W 4W one, you only save 4 watts.
IMO it's better to focus on quality: no flicker first, then higher color rendering bulbs which have a bit lower efficacy, but they are absolutely worth the extra watt. If you like the color rendition of halogens, the 3000K CRI90 spots from Osram are a nice match.
bobflux
  • 70,433
  • 83
  • 203
    IMO, lumens per Watt is not everything. Comparing an incandescent bulb with a bad LED with bad CRI (at the same lumens), I think it is easier to see stuff with the incandescent bulk, contrasts are more natural etc. so the better the CRI, the less lumens I need for the same perceived contrast level. So I agree, that CRI is more important than pure lm/W. PS: I don't want to lobby incandescent bulbs, but I advocate good LEDs with high CRI. There are now bulbs with advertised CRI way over 90 – tobalt Jan 03 '22 at 08:38
    @tobalt absolutely agree, there are nice inexpensive bulbs in [90CRI](https://www.lampesdirect.fr/osram-parathom-gu10-par16-4-5w-930-blanc-chaud-dimmable-equivalent-50w-4058075608290), and really good ones (like ExpertColor with CRI97), and we're finally getting out of the yellow overdose as 3000K becomes much easier to find. The GU10 are even better than halogens, I certainly don't miss them. – bobflux Jan 03 '22 at 10:42
  • Incandescents may not be commonly _sold_ anymore, but they're definitely still around. – Vikki Jan 04 '22 at 04:53
  • Aren't both luminous flux [lm] and energy consumption [W] always printed on the box? – gerrit Jan 04 '22 at 08:56
    To address your aside, it's because burning diesel produces a lot worse pollution than burning petrol. To the extent that there was massive industry fraud attempting to hide it that was uncovered in 2015. – OrangeDog Jan 04 '22 at 16:02
    @tobalt ... which is why I stuck with real fluorescent... every shop has 90 CRI tubes at non-premium prices. – Harper - Reinstate Monica Jan 04 '22 at 16:36
15
To add to Marcus's answer, the luminous efficiency of that bulb is 78 lm/watt at a CRI of 80-90. In an absolute sense that is fairly good, reaching something like 20% of the theoretical perfect efficiency for a white phosphor LED at that CRI value, which is far better than an incandescent. However, LEDs can be extremely efficient, and diodes in that CRI class of about 200 lm/watt are available. Thus in a relative sense, those lights are quite poor, using about 2.5x more energy then is required for that amount of light.
Think carefully about how often you will use the lights and the absolute amount of energy savings. A 6w light used an hour a day will not save a large amount of electricity if you double the efficiency. A 50w flood light used 12 hours a night will benefit a lot more from higher efficiency.
user1850479
  • 14,842
  • 43
