I am designing a DC-DC Buck converter using the ISL81806
I would like to use a sub-milliohm current sense resistor (0.2 milliohm) to set the current limit although it seems that the feedback voltage is a set value of 82 mV which would require a 4 milliohm current sense resistor to achieve my desired current limit (25 A).
Is there a safe way to adjust the op amp reading on the current sense resistor such as using a resistor divider network to gain the benefits of a sub-milliohm resistor while maintaining the same current limit?
