The DC blocking cap does what its name implies: it makes your amplifier have zero gain at very low frequencies (DC and close to DC; DC = 0Hz by definition).
Many audio sources may have a DC offset added to the signal. Such offset may be larger than the signal itself. So when you apply gain in the amplifier, that irrelevant DC offset may become a voltage much higher than the signal amplitude, potentially saturating the amplifier. Recall that an amplifier of the kind you are showing can't produce voltages higher than its supply rails (at most).
An audio amplifier that puts out a DC offset may damage the transducer at its output - say a headphone or speaker - since it'll dump much more power (due to combined DC+AC) into the transducer than the transducer was designed to handle.
In your case, the "blocking" capacitor on the input forms a high-pass RC filter with the adjacent 100Ohm resistor. The cutoff frequency is \$f_{hp}={1 \over 2 \pi R C}\$, here very approximately 1/(51E21E-6)=0.2*1E4=2kHz. That means that your audio amplifier will only provide full gain to frequencies above 2kHz. That's most definitely not what you wanted!
Change the resistor to ground from 100Ohm to 10kOhm, thus lowering the cut-off frequency by a factor of 100, down to ~20Hz :)
