I want to measure the relative intensity noise between 0 and 1 MHz of a laser using a photodiode (20 MHz BW), a voltage amplifier (10 MHz BW), and a spectrum analyzer. Since I don't have so much knowledge about electronics, I would like to clarify some things and like to know what the best "setup" is.
In order to not crash the spectrum analyzer (0 V DC allowed at input) I need a DC block. Do I put the DC block before or after the voltage amplifier?
The voltage amplifier can be DC- and AC-coupled. Which is the best setting?
In order to suppress the repetition rate of the laser (50 MHz) I need to use a 11 MHz lowpass filter. Do I place this before or after the voltage amplifier?
Where do I need to put 50 Ohm terminators? I suppose after the photodiode to convert the photocurrent into a voltage. But do I also need one after the amplifier and before the spectrum analyzer?
Basically I want to have as little electronic noise as possible from the setup to precisely measure the laser noise and not be determined by the electronic noise itself.
Photodiode: DET05D2 from Thorlabs
Amplifier: HVA-10M-60-B from Femto
Spectrum analyzer: E4443A from Agilent
