I have a number of variable power packs one of which supplies the 5volts I need to for a particular device. The output is "500mA MAX". I worry that as happened once before with an ipad I might burn something out but I don't really understand what the amperage is all about (i.e. how do you work out if a specific amperage is OK, and what happens if it's not?)
Asked
Active
Viewed 48 times
It’s a bit like cash. If you have more Amps than required, then you’re ok. If you don’t have enough, that’s bad. Personally I’d avoid using random power supplies on expensive gadgets. You gets what you pays for. – Kartman Dec 08 '21 at 00:22
If apple did't current limit protect their outputs, I'd be surprised – Tony Stewart EE75 Dec 08 '21 at 00:34
