I am a novice, and I'm playing around with SMD magnetic buzzers. For instance, the CUI CMT-322-65-SMT-TR.
In the datasheet they recommend something like this: enter image description here
After some Googling I learnt the diode is a flyback diode, which prevents the transistor from being damaged when power is cut.
My question is: how do I know which diode to use?
In this case, the +VDC powering the buzzer would be 3V. Do I need a regular, Zener or Schottky diode? Regardless of the type, what kind of characteristics should I then be looking for in this specific configuration?
This is an SMD project, but since I'm just experimenting I can also play around with through-hole diodes if you have any suggestions.
TonyM
  • 21,742
  • 39
  • 62
peanutman
  • 145
Take a look at the data sheet: -
So what this tells you is: -
  • It's a magnetic device and not a piezo device
  • The rated voltage is 3 volts p-p typically
  • At the rated voltage the current consumption is 120 mA
Doublechecking the numbers, 50% of 3 volts divided by the typical coil resistance (12 Ω) is 125 mA peak current. Not far off so believable.
Use a diode that is rated at a forward current of at least 125 mA. Maybe go for the inexpensive 1N400x series of diode. There isn't anything particularly onerous in this circuit that requires anything other than a standard diode but, if you have a Schottky diode to hand, that wouldn't be a problem either.
You should not attempt to run the +Vdc supply any higher than 4 volts for this type of buzzer hence, don't employ a 5 volt supply unless you put a resistor in series with the buzzer to limit that peak current to below ~120 mA.
You just need a fast diode that operates in forward conduction which rules out Zeners. "Regular" PN diodes are typically for 50/60Hz rectification so can be slow because they do not need to be fast.
So could be a fast PN, Schottky, whatever. Schottky diodes are inherently faster than most but sometimes you can't find them in the required voltage or current ratings.
You could also use a low-value (1-10 Ohms probably) series resistor and ceramic cap (100nF-1uF probably) instead for an RC snubber and be just fine.
Make sure to learn why the flyback diode or snubber protects the transistor and you won't need to ask this question.
DKNguyen
  • 54,733
  • 67
  • 153
  • Thank you for the info! This also helped me a lot, but sadly I can only pick one response as the "answer". – peanutman Dec 01 '21 at 15:12
It hardly matters, however, you don't want to use a diode so absurdly large that it is slow to turn on. Zeners are inappropriate here.
Fast is good. Schottky diodes tend to be fast.
evildemonic
  • 8,698
  • 44
