I'm new to RISC-V and I'm having trouble understanding how one would store specific values in large addresses. For example, if I wanted to store the value 5 in 0x12312312, how would you go about that?
Asked
Active
Viewed 1,061 times
It requires two steps. "Load upper immediate":
and add the 12 LSBits:
Images source: "The RISC-V Instruction Set Manual Volume I: Unprivileged ISA"
Example to build any constant/address: a5 = 0x12345678
lui a5,0x12345000(305418240)
addi a5,a5,1656
For values with all 12 LSbits = 0, only lui
is required. For small values, addi
to register 0 is enough.
Another example: add 65535 to a pointer stored at address (a3):
lw a5,0(a3) -> load the base address, stored in (a3) to a5
lui a4,0x10 -> "build" the initial MSBit of the constant
addi a4,a4,-1 # ffff -> "build" the final value of the constant
add a5,a5,a4 -> calculate the new adress
sw a5,0(a3) -> store the new address
devnull
- 8,447
- 2
- 15
- 38
1This clears stuff up. I guess if you're in a situation where you need to add more than 2047 to an address, you just use the addi instruction twice? – Anthony Nov 29 '21 at 11:04
1I've added another example. It gets simpler for small values, as you mentioned, and also with shifts with all 12 the LSBits equal 0. – devnull Nov 29 '21 at 11:21
