It seems like there should be a million chips for this, but for the life of me can't find any. I'm looking for a small (SOT23 or similar size if possible) IC that provides an active high when the supply voltage goes ABOVE a setpoint, and open circuit when below. Looking for ~3V trigger with up to 6V operation.
There are plenty of reset monitors that pull low when the voltage drops below the setpoint, but all the ones I've found only work down to a certain voltage, and go open circuit again when volts totally disappears. I'm using 2 different power supplies so that doesn't help me. I'm currently using the STM1061N31WX6F but discovered it doesn't work for me when there's no supply at all.
I could of course do it with several discrete components, opamps, even a microcontroller solution, but I was hoping there was a single chip solution. Google and Digikey are not being my friend today.
