The image below shows the formula for the bandwidth of pulse code modulation (PCM.) There are two questions I want to ask:
Bandwidth of the PCM signal waveform is bounded by \$ B_{PCM} = \frac{1}{2}(R) =\frac{1}{2}(nf_s) \$
R is the bitrate and since this is a square wave, the fundamental frequency will be the frequency of the square wave itself (according to Fourier transform, I think.)
Why does R needs to be halved? (I thought it must be R itself since that is the fundamental frequency.)
For one using a rectangular pulse with polar NRZ line codes = \$ B_{PCM} = R = nf_s \$ (first null bandwidth)
Why in this case does the bandwidth become R itself just because the coding technique is polar NRZ?
JRE
  • 67,678
  • 179
hontou_
  • 1,044
If your bit rate is 1000 bits per second, when the bits are changing at the maximum rate (10101010 etc.) it is effectively a square wave of 500 Hz. That's where the divide by 2 comes in.
  • Okay I got now that part, thanks! How about polar NRZ not needing divided by 2? – hontou_ Nov 20 '21 at 14:38
  • Might it be referring to something like Manchester encoding. There's probably not enough info contained in your extract in tour question so I can't tell. – Andy aka Nov 20 '21 at 14:49
  • @hontou_ if we're done here then maybe you should accept this answer or ask for more clarification in a comment. – Andy aka May 28 '22 at 13:59
