15
Can someone tell me what the difference between linear regulators and LDOs is?
From what I have read and understood, it is that linear regulators and LDOs don't use switching elements, but I think they are the same basically.
Is there something that I am missing to understand?
JRE
  • 67,678
  • 179
    Ldo is more marketing term than anything. Your grandpoppop's LDO wouldn't be considered an LDO anymore. – Passerby Nov 19 '21 at 06:49
    The difference is the dropout voltage. –  Nov 19 '21 at 15:03
  • A thorough explanation of LDOs can be found here: https://www.ti.com/lit/ml/slup239a/slup239a.pdf?ts=1687827449023&ref_url=https%253A%252F%252Fcn.bing.com%252F#:~:text=There%20are%20two%20types%20of,maintain%20a%20regulated%20output%20voltage. – KRitiCal_m4ss Jun 27 '23 at 14:12
An LDO is a type of linear regulator.
All linear regulators have what's called a dropout voltage, a minimum input-to-output differential that they can't work without. The original linear regulators (including the still-popular 78xx and 79xx series) had dropout voltages on the order of 2~3 volts.
Since the input-to-output differential is directly related to power loss (among other considerations), it's desirable to operate with as low a differential as possible. So the low-dropout (or LDO) linear regulator was invented. Initially, these had dropout voltages in the range of 1~2 volts (such as the LM1117 series), but that would hardly be considered "low" dropout today; modern LDOs can achieve dropout voltages of only a few hundred millivolts.
It's not recommended to use an LDO when you don't need one, though, as they tend to have poorer stability characteristics than standard linear regulators. A 78xx is typically stable no matter what as long as you give it adequate capacitance on the output, but a fancy LDO with only 100 mV of dropout may require the output capacitance be in a narrow range, and that capacitance needs to have high enough (but not too high) ESR to avoid oscillation. See this question for some more details on this.
Hearth
  • 27,177
  • 51
  • 115
35
They key property of the LDO type linear regulators is the P-type pass transistor. This allows controlling the pass transistor with a voltage below the input voltage \$V_{in}\$ for all possible output voltages. Therefore, the output voltage can in principle be set arbitrarily close to the input voltage, especially for MOSFETs.
Non-LDO type regulators that use N-type transistors have an inevitable dead band of output voltages close to \$V_{in}\$ in that they simply cannot reach, because those high output voltages would require a control voltage on the pass transistor above \$V_{in}\$.
tobalt
  • 18,646
  • 73
  • The p-type pass transistor usually is working in its active region right, during the Linear regulator regulation? –  Nov 19 '21 at 07:30
  • This is what nails the important difference. So +1. – jonk Nov 19 '21 at 09:19
  • @Newbie I'm not good with those names and I think the region names are even different for MOSFET and PNP. The transistor is usually close to its turn-on control voltage. It will be neither shut off nor saturated-on. – tobalt Nov 19 '21 at 09:25
    @tobalt The relevant mode is called forward active for BJTs, and saturation for FETs. – Hearth Nov 19 '21 at 14:01
    @Hearth thanks for adding that! I think it is a little confusing (albeit technically correct) to call the MOSFET region saturated, because when thinking in switch jargon, saturated would imply that it cannot be turned more on. But then again, I might I have a weird perception for these names because I've never really thought much about them or used them as a self-learner. – tobalt Nov 19 '21 at 14:26
  • @tobalt The idea is that the channel is saturated with current, it can't sustain more current without enlarging the channel by further inversion (via more gate bias). – Hearth Nov 19 '21 at 14:28
  • @tobalt Basically that you can't get any more current by increasing the voltage on the drain (bar channel-length modulation, anyway, but that's a non-ideal effect). – Hearth Nov 19 '21 at 14:29
    @Hearth I see where the name is coming from. If you view the gate voltage as a given, then the channel is saturated. But looking slightly further, there is of course the elephant in the room, that the gate voltage could be easily raised. For a JFET e.g. the saturation current can't be easily enhanced. But as I said, the term is technically absolutely correct, it just feels a bit weird to me from an application pov, to call a MOSFET that is barely on "saturated" (and I know it feels weird because *I* am weird :p) – tobalt Nov 19 '21 at 14:34
  • @tobalt, just a small doubt. When you say,"This allows controlling the pass transistor with a voltage below the input voltage", could you tell me how it is controlled? Like, the base emitter of the PNP is controlled how ? –  Nov 19 '21 at 15:23
  • @Newbie the simplest way to think of the internal circuit is as an op amp that has the PNP base at its output. This opamp can output voltages up to Vin as it is powered from Vin. It pulls the base to ~0.65 V below Vin and then regulates it slightly up down to just allow enough current through, so the output voltage will stabilize at a desired level. The output voltage is fed to the IN+ of the op amp and the reference voltage is fed to the IN- of the op amp. (The inputs are in the 'wrong' order because the P-type pass transistor has inverting gain. – tobalt Nov 19 '21 at 15:30
  • @Newbie however the control circuit can be as simple as a single PNP transistor in the case of flipped voltage follower (FVF) LDOs. See this reply as an example: https://electronics.stackexchange.com/a/583712/237061 – tobalt Nov 19 '21 at 15:32
  • @tobalt The wording of this answer is a little misleading; you can control an N-channel or NPN transistor with a voltage below the input voltage too. The problem is that the control voltage for N-type transistors has to be higher than the *output* voltage. – Hearth Nov 21 '21 at 13:18
    Completely agree @Hearth Atm this answer offers a very simple explanation. I thought about adding more precision on how to control P or N type transistors, but then I thought that this would sacrifice brevity and complicate matters too much for those looking for a simple explanation. I will slightly change it hoping to achieve both. – tobalt Nov 21 '21 at 13:55
12
A low drop out regulator (LDO) is a linear regulator.
Linear regulators control the output voltage by adjusting the current through an output transistor.
In all linear regulators, there is a minimum difference between the input voltage and the output voltage that you have to maintain.
Take the ancient 7805 linear regulator. It needs the input voltage to be at least 2V higher than the output voltage. You need at least 7V in to get 5V out of a 7805.
By comparison, the TLS850C2TEV50 only needs a difference of about 0.1V between input and output. You only need 5.1V in to get 5V out. That's "low drop out."
Both are linear regulators.
The TLS850C2TEV50 is a low dropout (LDO) regulator.
The 7805 is a linear regulator but not a low dropout regulator.
JRE
  • 67,678
  • 179
A low dropout regulator is a type of linear regulator where the drop out voltage is relatively low. For example, an LDO might require an input voltage only a few hundred millivolts above the output voltage, while a classic linear regulator like the 7805 requires at least 2 volts.
For more information, see: https://en.wikipedia.org/wiki/Low-dropout_regulator
user1850479
  • 14,842
  • 43
