I am unsure of the formula used to calculate the feeding gap of a dipole antenna. When I go through some research papers, the formula given to calculate the feed gap of a dipole antenna is L/200. I know that the minimum gap is zero and the maximum is lambda/2, but what is the reason the length is divided by 200? What does 200 stand for?
Asked
Active
Viewed 248 times
As you move away from the ideal "zero gap", the input/output impedance to/from the dipole antenna changes from the standard value of 73 Ω + j42.5 Ω to something different and less documented. Hence, we have a rule of thumb that says if the gap is small (one-two-hundredth) of the dipole length then the impedance quoted above is reliable.
- 28
- 351
- 777
L/200 is not a 'formula to calculate a feed gap', but the value your research papers used for 'small', when providing a small feed gap in a dipole. L/100 and L/300 would give very similar results. The papers documented what they used, in the interests of reproducibilty.
Neil_UK
- 158,152
- 3
- 173
- 387
