For one of the four S-parameters - the S21 - why is that S21 can be translated as 2Vout/Vgen?
Is there a simple explanation for it?
S21 is the output voltage divided by the input voltage when the "circuit being measured" is properly impedance matched to the source and correctly impedance loaded on the output.
So, the act of applying an ideal voltage source (\$V_{GEN}\$) via a matching impedance to the "circuit being measured" is to reduce the actual input voltage to the "circuit being measured" by 2. Hence, with respect to the ideal voltage source (\$V_{GEN}\$), S21 has to be: -
$$\dfrac{V_{OUT}}{V_{GEN}/2} = \dfrac{2\cdot V_{OUT}}{V_{GEN}}$$
