I have a cabin in a remote location in Norway, and as luck has it, no cell phone reception. There is great reception up on a hill nearby. I could erect an antenna there, and the cable would be about 180m if I were to lay one from the cabin and to the top of the hill, but given the length, the amount of signal loss would make the antenna worthless.
So I need to evaluate some alternatives and the basic premises I have found I need to base solutions upon are:
- terminate the antenna in a 4G router at the spot to avoid signal loss
- use TCP/IP to transmit signals down
So a router requires power, so I thought about pulling 220V power and ethernet cables from the cabin and up to the antenna. Unfortunately, AFAIK Cat5 ethernet cables need to be a maximum of 100m. That leaves that option out, but can I transmit the signals in some other fashion, like the "pringles wifi can" directed antenna?
Are there other options worth considering?
