I am trying to isolate part of my circuit with a voltage follower (LM7171). The signal at the op amp non-inverting input is PWM (12 V, 0 V) with a frequency of 20 kHz. It is attenuated by the voltage divider (6 V, 0 V) when the op amp is not connected.
When the op amp is connected to (+12 V, 0 V), the PWM at the non-inverting pin shifts from (6 V, 0.9 V). What's causing this offset in the PWM?
I thought it was caused by the grounds but I have disregarded it already by connecting all the grounds as close as possible.
