TL;DR:
My system needs DC power input--maximum of 250W @ 24V--but with the use of an A/C power source. How do I go about this? I have no idea where to even acquire a DC power supply, but I'm not sure if that is the correct angle, as they're pretty pricey.
I am a mechanical engineering student, in his final semester. For our group's Capstone project, we made a shredder, and now just need to power it.
We purchased a 250W, 24V DC motor, along with a proper PWM DC Motor Controller to control its speed. The controller listed requires DC power in. https://www.amazon.com/RioRand-Controller-Efficiency-Generating-Protection/dp/B007TH4EN6
So far, I have wired the motor to the controller, and the controller to a "generic" wall plug from Lowe's. The third prong (ground) cable was left alone, as neither the motor nor controller has a spot for securing it. https://www.lowes.com/pd/InSinkErator-Power-Cord-3-ft-3-Prong-Black-Garbage-Disposal-Appliance-Power-Cord/1269937
The hot wire is attached to the power (+) terminal, and the neutral into the power (-) terminal. Then the motor is attached appropriately (but the ends can be swapped around based on which direction I want the motor to spin).
How would I have my DC system above powered with an A/C power source? I was tempted to go ahead and plug it into the wall, but don't want to risk frying any parts.
Thank you!
