Above is the picture of how I approach the 3(ii) question. My question is,which way is the correct way of finding line/phase currents/voltages? Why is the line/phase current different for each method?
Asked
Active
Viewed 128 times
Hello incognitomodus, Thank you for the clearly formatted question. Both methods should work and give the same answer when done correctly. I haven't worked though the problem however I put a simulation of the problem circuit in your question, with it you can check your answers and see what might be going on with you calculations. – Some Sorta EE Oct 20 '21 at 17:15
Hi , can I know how you simulate and run the circuit on falstad.com? Cause I always get no currents flowing in whenever I tried to simulate any circuit? – incognitomodus Oct 24 '21 at 15:41
That's strange. There is a Run/Stop button on the right of the screen otherwise the simulation should be running continuously without input from you. Try another browser or computer. Otherwise I can't say why it wouldn't work. – Some Sorta EE Oct 26 '21 at 17:18
