I've tried routing before and after pouring a GND on the bottom layer. I get many GND traces running on the top layer for no apparent reason? Tried without a GND layer, added it after the auto-router - but it did not help.
Any idea what would be the best way to make sure the router puts a via near SMD components that should connect to GND on the bottom side and not run traces?
TonyM
  • 21,742
  • 39
  • 62
user733606
  • 435
It's simple; don't use an auto-router. The details in your question clearly indicate that your auto-router is stupid so, don't use it. If you insist on using your auto-router then manually connect GND tracks to the ground-plane with vias and delete the offending track.
In all my history of designing PCBs, I've never used an auto-router and I don't intend to start any time soon.
Neil_UK
  • 158,152
  • 173
  • 387
    You'd think that auto-routing would be a solved problem by now - at least for not too complex boards, but despite advances in AI and processing power of seems like we're still not there... – brhans Oct 17 '21 at 12:23
  • Apparently, for those designing backplanes, it's useful @brhans. Probably because connector positions are a fixed thing mechanically. – Andy aka Oct 17 '21 at 12:24
    This is absolutely the correct answer. – DerStrom8 Oct 17 '21 at 12:25
