I've referenced many symbol sheets with no avail.
What would JP5 'AutoON' be here? I assume it's a switch that is default on, but the symbol is foreign to me.
Blake
  • 503
The symbol and 'JP' label suggest that it is a jumper used to bypass the switch.
Figure 1. A 2-pin jumper on a 5-way pin header. Image source: Sparkfun.
Transistor
  • 168,990
  • 186
  • 385
    Another use for the jumper pins could also be to install an alternative remote switch, either for integration into a larger system or for automation of the power-on function by a micro or logic controller, etc. – J... Oct 14 '21 at 14:40
The JP5 is most likely just a standard jumper block, maybe a standard 2.54mm/0.1" pin header with two pins, allowing the user to use pushbutton manually when jumper is removed or short out the pushbutton permanently by mounting the jumper block.
Justme
  • 127,425
  • 261
It's a circuit breaker symbol used incorrectly to indicate a jumper block. Given that this symbol is quite universal, its misuse is misleading - the schematic's author might as well used no symbol besides the two terminals, and with the JP reference designator it'd have been obvious still what it is.
