I don't think this has been covered in other posts.
I have a 3.7V 6000mAh li battery pack and three 3.7V 2000mAh li battery packs. If I wire the three 2000s in parallel to make a 6000mAh cell, then wired that cell in parallel with the single 6000mAh pack, would that negate the issues of wiring parallel with batteries of differing capacity?
I am trying to increase the capacity of a power bank I just put inside a Bluetooth speaker I built, (think of JBL Charge series, but with more features and a much bigger battery.) I have the 6000mAh battery, and tons of smaller ones, and the idea occurred to me that if all the smaller ones were identical in age, capacity, voltage, and charge, and I matched their total charge (6000) to the other battery (6000) then for charge/discharge purposes that might alleviate the load on any other batteries in the parallel whose total capacity is less than the largest.
What do you think? Might it work? If not, is there anything I can add into the circuit to allow me to use the diverse capacities I have of battery? My thought was just adding a switch, to switch from the 6000mAh battery to the three 2000mAh parallel battery cell.
