Thank you for reading. I have read many other voltage divider explanations and calculators on this site as well as the web. My application is using a voltage divider to lower a possible 5 V signal (output of 5 V pressure sensor) to an input of my ESP32 dev board (doit ESP32devkit1 v4). I will being using ADC. The purpose of the project is a pump controller for the water system at my home.
I understand the concept of the voltage drop across the resistors and the calculation. The thing banging my brain is at what point am I setting the input to the ESP by my voltage divider rather than my pressure sensors? Is the point to keep high values on the divider such that my pressure sensor can overpower the voltage divider? Or am I missing something basic?
In the event of the overpower what values should I pick for a minimum? I am on line power so I'm not worried about battery life. In the end this controller will be using a number of inputs for everything from a second pump sensor to the end of my washer or dryer to weather sensors for the sprinkler system. I short I'm more worried about the concept involved than actual values, I have a good selection of resistors so that should be OK.
