Recently I got into an argument with my physics teacher over a simple subject, with this question - "What kills you, the current or the voltage?". I argue that it is the voltage that kills, not the current. His reasoning was that the size of the current determines your death because the current is what actually stops your heart, not the voltage. My argument is that the voltage is like the key that unlocks that death. For example, let's say you had a power supply with a 10 amp limit. 10 amps through the body is definitely enough to kill you. Obviously just because it has a capability of 10 amps, it doesn't mean touching the leads will instantly kill you, this is because:
Let's say you have these parameters:
Scenario 1
Voltage: 1 V
Resistance: 10 kΩ
Scenario 2
Voltage: 230 V
Resistance: 10 kΩ
In Scenario 1 the current would be 0.0001 Ampere (0.1 milliampere), according to the scale below, this wouldn't even be noticeable if the current was passing through a human body.
Now lets see Scenario 2. The current would be 0.023 ampere (23 milliampere), according to the scale below, this would be very noticeable. Your muscles would begin to freeze uncontrollably, and you could have respiration and muscle paralysis, this could potentially stop your heart (killing you).
The only noticeable difference is the voltage. If the resistance remains the same but the voltage changes, the obvious factor would be the voltage that affects you. I also think that a number of factors change it too: the timing of the shock, the frequency, the type of current, etc.
At the end of the day, what I'm asking is "Is it the current responsible for the death of someone, or the voltage".
