I try to establish a communication with the TM4C123GXL and the AD9826. For the communication I use the SPI interface of the TM4C123GXL. The SSI Rx and Tx are connected via a 3 kOhm resistor.
The AD9826 requires the following timings. Serial Read Operation Timing AD9826
With the SPI peripheral from TM4C123GXL I generated the following timings, where blue = clock, turquoise = data and purple = sload
Tektronix DPO3034 Screenshot
Unfortunately I do not get a response from the AD9826 or rather it is wrong. I try to read the content of the configuration register which has the address 0x000. So by adding the address bit it would be 0x1000000. The response which I expect would be 11111000 - which is the default value for the configuration register.
So this raises the following questions to me.
  1. Does the AD9826 need a continuous clock? (This would be a problem, as the TM4C123GXL SPI peripheral cannot provide it).
  2. Is this three wire "SPI" a SPI kind of communication? (For me it looks like the MICROWIRE frame format)
  3. Any idea what I am doing wrong?
  4. Is the read bit high or low? I assumed that it is high from the picture below. There is no further indication in the datasheet. enter image description here
Johannes
  • 207
There is a mixup in the addressing of read and write operations.
The first bit is the R/Wb bit and it is low so you are doing a serial write operation to address 100 in binary. For a read operation the R/Wb bit would be high.
Justme
  • 127,425
  • 261
  • Thanks, unfortunately it still does not work. Is it by convention that the write bit is usually one and the read bit is usually zero? I extended my question regarding the write and read bit. – Johannes Oct 06 '21 at 10:49
  • @Johannes According to what convention? There is no convention. The chip datasheet just says this chip works like this. Read is high, write low. – Justme Oct 06 '21 at 11:04
  • you're right. I shifted the bit and it looks good now. thx – Johannes Oct 06 '21 at 11:44
Justme is right. The first bit of the data signal must be shifted to the left, so that it aligns with the first clock pulse.
After some investigations I can answer the following.
Serial clock can be turned off if no read or write operation is done. (see Analog Devices Engineering Zone)
  1. Is this three wire "SPI" a SPI kind of communication? (For me it looks like the MICROWIRE frame format)
For the TM4C123GXL the Motorola Freescale Frame Format must be used (see initialization code below)
        SSI2_CR1_R &= ~SSI_CR1_SSE;
        SSI2_CC_R = 0; // using system main clock
        SSI2_CR0_R |= (scaler<<SSI_CR0_SCR_S);
        SSI2_CPSR_R |= clkDivider;
        SSI2_CR0_R |=  SSI_CR0_FRF_MOTO; // Motorola Freescale Frame Format
        SSI2_CR0_R |= SSI_CR0_DSS_16; // 16 Bit data
        SSI2_CR1_R |= SSI_CR1_SSE;
  1. Any idea what I am doing wrong?
    Apart from setting the bit on the wrong position, I selected the wrong frame format.
  2. Is the read bit high or low? I assumed that it is high from the picture below. There is no further indication in the datasheet.
    Read bit is high.
In addition I can share the following outcomes.
Johannes
  • 207
