I have been using Xilinx FPGA devices for a while and I use HLS extensively to create parts of my design.
I have currently switched to Actel FPGA devices and specifically the ProASIC3 family, and wanted a similar functionality like HLS (Embedded C or custom IP design feature), for the Libero and SynplifyPro tool and was not able to find such a feature, thus making me handicapped.
Any ideas or workarounds on making HLS like feature exist in Actel FPGA programming as well?
abunickabhi
  • 354
    doesn't Vivado HLS translate that "custom C" into usable VHDL at some stage? –  Oct 06 '21 at 12:21
  • Yes it does convert it. It is converted at the stage when the IP is generated out of the user written C code and testbench. My question is that "Is there any converters and tools for doing high level synthesis on the actel devices"? – abunickabhi Oct 06 '21 at 12:34
    You also asked about workarounds. Using VHDL may be a workaround. (I make no claims that the licensing of either toolset permits it, nor that the auto-generated VHDL is actually usable). However, you will probably find that simply using VHDL (which is designed for hardware synthesis) is actually easier than using some bastardised C (which is not). The trick is to use VHDL at a higher level than most teaching materials do. –  Oct 06 '21 at 12:35
There is a tool for working on High level synthesis and write C like code that gets transformed to verilog/vhdl code. The tool is called SmartHLS by Microsemi.
Smart HLS user guide
It is eclipse based dev environment and can be integrated with libero.
abunickabhi
  • 354
  • HLS is only supported for IGLOO, Polar and SmartFusion devices. There goes my dream of programming ProASIC chip using HLS. – abunickabhi Oct 21 '21 at 13:51
