I have tried to understand the simple circuits in the questions Intuitive and iterative approach to understanding of blinking LED circuit and Changing the frequency of a flashing LED. I've built them and they don't work. I've simulated them and they won't work. I looked at them and I don't understand how they could work.
Here is the circuit in question (diagram mine, adapted from the linked articles; I have copied the polarity of C1 carefully from the original diagram):
"blinking" LED
Now I understand how a small control voltage can switch a much higher "load" voltage. That's described in AoE, and the relevant diagram is Fig. 2.10:
Switching high voltages with low control voltages
But in trying to modify this figure to end up with the "blinking" circuit, we would at least have to remove the pull-up resistor R3. So in the "blinking" circuit, the base of Q2 is floating whenever Q1 is off, isn't it?
When I try to understand the dynamic behaviour of this circuit, I am reasoning as follows:
  • Initially, C1 is discharged and all transistors are off
  • When applying the supply voltage, current will flow through C1 (incidentally with the wrong polarity), and Q1 will begin to charge. As long as the voltage across C1 is low, Q1 will stay off. The time constant is the product of the values of R1 and C1.
  • Eventually, Q1's Vbe will be enough to turn Q1 on and a current of 0.9 mA will flow into Q1's base
  • Because Q1 is now turned on, base current can now flow out of Q2's emitter, turning Q2 on
  • Collector current flows through Q2, turning on the LED
  • Since the LED's forward voltage is (likely) higher than Q1's Vbe, C1 will now begin to charge in the "right" polarity
And now I'm stuck. First notice that there are voltages across C1 in both polarities, so I'm not sure how one can use a polarised cap in this situation at all safely. Also I don't understand how Q1 is turned off. As I said, I built the circuit and it doesn't work, and I've simulated the circuit and it doesn't work, so my tentative conclusion is that it really doesn't work.
My questions are:
  1. Are there mistakes in my reasoning, and if yes, what are they?
  2. Are there small modifications that one can make to the circuit so that it does indeed blink?
  3. It seems to me that the circuit might behave differently when the LED is replaced by an ohmic load such as an incandescent lamp; what would be the consequences?
Null
  • 7,448
  • My first problem is that you don't have a current-limiting resistor for the LED. My second problem is that, assuming it works at all, you are likely hammering the base with very negative voltages continually avalanching the base-emitter junction. Finally, it can't work with those values for R1 and C1. At least, I don't think so. I think it would just pull the LED on (at crazy current) and that's that. I'm going to sleep now, though, so perhaps someone else will sort it for you. Meantime? Put a 220 Ohm resistor in series with the LED and reduce C1 (a lot) and increase R1 (a lot.) – jonk Oct 02 '21 at 09:19
    I'll close with this. You have two BJTs with lots of current gain. Let's say 150 each. Those get multiplied. So what's 20 mA for the LED divided by 150 squared? Not much. That's the base current needed for Q1. Not much. And with say 8 volts through R1 to deliver it? R1 needs to be very high -- Meg-Ohms high. And it doesn't take much of a capacitor to tilt that this way or that. The capacitor is crazy big unless you like long pulse durations. – jonk Oct 02 '21 at 09:28
  • See also:https://electronics.stackexchange.com/questions/261288/understand-2-transistors-npn-pnp-flasher-circuit-working – Russell McMahon Oct 03 '21 at 09:25
Yes. Without a power supply I'd pretty much agree.
But even at \$t=0^{+}\$ just when power is applied, since \$C_1\$ starts out (assuming the circuit has had time to completely discharge everything) with \$0\:\text{V}\$ across it. The LED current is assumed to be zero, at start (though I hate making such assumptions without more study.) So the voltage drop across the LED should also be \$0\:\text{V}\$. That ties one end of \$C_1\$ to ground (through an LED, though) and this implies then that the base of \$Q_1\$ will be at ground, as well. So, with \$Q_1\$ off there should be no collector current for \$Q_1\$ and therefore no base current for \$Q_2\$ and therefore no collector current for \$Q_2\$ and.. well, no LED current. Q.E.D.
Not at all the way I'd visualize it, though I do agree that given the capacitor polarity you show, the increasing capacitor's voltage differential will be opposite to the shown polarity.
With the supply voltage applied, current through \$R_1\$ will achieve two things: increasing base current for \$Q_1\$ and decreasing charging current for \$C_1\$.
Yes, pretty much agree with this. The base current in \$Q_1\$ will be miniscule at first and will not be sufficient to meaningfully affect \$Q_2\$ until the \$Q_1\$ base voltage is able to rise upward, sufficiently.
Well, given \$R_1\$'s value and the fact that \$Q_1\$ requires a base-emitter voltage that is getting meaningful, I'd make it more like \$800\:\mu\text{A}\$.
Note that this implies that, if \$R_2\$ weren't present, the base current out of \$Q_2\$ will be about \$\beta_1\$ times this figure. However, \$R_2\$ allows \$Q_1\$ to saturate and therefore does limit it to about \$8\:\text{mA}\$, instead. (It turns out that this suggests the hand of a designer here, as the saturation \$\beta_1=10\$.)
So the collector current of \$Q_2\$ can be (assuming a modest \$\beta_2=120\$ for a PNP) about \$960\:\text{mA}\$! Without another resistor here to allow \$Q_2\$ to saturate, the LED voltage will (in theory) keep \$Q_2\$ out of saturation. So the high \$\beta_2\$ value likely applies.
And this is a problem.
So this is where you stop for a moment and insert a series resistor (\$R_3\$) between the collector of \$Q_2\$ and the LED anode. This allows \$Q_2\$ to saturate and allows the LED to also operate at a reasonable applied voltage.
In adding \$R_3\$, I'd retain the now-loose end of \$C_1\$ at \$Q_2\$'s collector and no longer to the LED anode. Here, I'd probably set \$R_3=220\:\Omega\$ (it's a pulse current so I'd allow something higher than \$20\:\text{mA}\$, to start.)
I think you mean that base current in \$Q_2\$ allows its collector to start supplying LED current. And yes.
Yes.
Good breaking point.
Before I write the following, just some notes.
The LED doesn't have a static "forward voltage." It has a voltage that is proportional to the logarithm of the current through it. It's almost never zero volts and it's never constant unless the current through it is also constant. So as this circuit first starts up, \$Q_1\$ despite being "off" in what you write, isn't really actually off. So it is supplying active mode base current to \$Q_2\$ which is supplying a little LED current and that will generate a voltage across the LED, etc. You can idealize this. But it's actually nuanced.
In addition, \$Q_2\$ has a 'capacitance' between its emitter and collector and this capacitance will initially also pull up \$Q_2\$'s collector when power is applied, leading to an initial LED current. So your comment about \$C_1\$ initially keeping \$Q_1\$ off (and my above agreement) isn't really true. Instead, \$C_1\$ is pulled up by the collector-emitter capacitance of \$Q_2\$, turning \$Q_1\$ on for a moment. However, that capacitance is only some dozen pF so it doesn't take long to become charged (through the LED) so that \$C_1\$ is rapidly pulled down turning things off so as to meet with your expectations. This whole time period will be rather short, order of dozens of microseconds I think, as it should not take the exponential-related current of the LED (if \$R_3\$ isn't present -- a little longer if it is) long.
Back to the story. But the following story will assume \$R_3\$ and the ability for \$Q_2\$ to saturate. If there is no \$R_3\$ in your mind as you read below, then some of what I write below won't apply. Just FYI.
The collector current in \$Q_2\$ will rapidly rise up and this will create a necessary voltage drop across the LED (and, if you follow my earlier thoughts) and also \$R_3\$, pulling the collector end of \$C_1\$ rapidly upwards. But the other end of \$C_1\$ is already perhaps \$1\:\text{V}\$ higher. So this drives the base of \$Q_1\$ still harder than before, ensuring that the base voltage of \$Q_1\$ is crazy high (close to the positive voltage rail.) This is the positive feedback part of the cycle that ensures a very fast transition that jerks the collector end of \$C_1\$ upward, very quickly -- like a sharp "snap" upwards.
However, this causes a very high base current (exponentially related) in \$Q_1\$ which allows \$C_1\$ to rapidly charge from about \$1\:\text{V}\$ to about \$8\:\text{V}\$ in very short order (a few microseconds, maybe a little longer and depending on \$C_1\$'s value. \$Q_1\$ is in hard saturation and \$Q_2\$ is also in as hard a saturation as is possible, given \$R_2\$ current limiting. So now \$C_1\$ is charged to about \$8\:\text{V}\$, consistent with your illustrated polarity, and the LED current is at maximum.
Now this is the point where \$R_1\$'s value is critical and will determine whether or not the circuit oscillates or just finds a quiescent point and sits there. If \$R_1\$ is small enough (allows enough current), then it will just keep \$Q_1\$ on and in heavy saturation. The circuit will then just sit there with the LED on. It's stable.
But what if \$R_1\$ cannot supply \$Q_1\$'s base current at this hard-saturation level? What then?
Well, then \$R_1\$ supplies only a part of it. The rest has to come from... wait for it... \$C_1\$. As \$C_1\$ supplies its part of this \$Q_1\$ base current, the voltage across \$C_1\$ rises, gradually. Since the \$Q_2\$ collector end of \$C_1\$ is pretty much tied to the positive rail through the saturated \$Q_2\$ collector, this means the \$Q_1\$'s base voltage slowly declines. A large \$C_1\$ can supply the missing (that which is not supplied by \$R_1\$) current for longer periods. A smaller \$C_1\$ for shorter periods. Either way, the \$Q_1\$ base voltage declines and as it does, so also its ability to supply collector current to \$Q_2\$, needed to hold it in saturation.
Eventually, there isn't enough \$Q_1\$ collector current to keep \$Q_2\$ in hard saturation and the saturation softens (moves toward active mode.) As it does so, it's collector voltage widens away from its emitter (moves toward ground, a bit.) But this pushes one end of \$C_1\$ downward, which then also pushes \$Q_1\$'s base voltage down still further, which makes \$Q_1\$ even less able to supply \$Q_2\$'s base current, moving \$Q_2\$ still more towards active mode, causing its collector to widen still further away from its emitter, ... and you get the idea. It is the second positive feedback here that rapidly turns everything off.
This pulls the \$Q_2\$ collector end of \$C_1\$ towards ground quite rapidly and this drives the base of \$Q_1\$ into deep negative voltage regions, where \$Q_1\$'s base-emitter junction will avalanche. (This damages the BJT \$\beta\$, but doesn't necessarily cause it to stop working. So long as you don't care much about it, it should survive fine for a while in this circuit.)
There are two things missing from your consideration in making this work well. One is a current limit resistor for the LED which is necessary in order to allow \$Q_2\$ to saturate, to protect the LED, and to protect \$Q_2\$. The other is the sizing of \$R_1\$ such that it cannot keep \$Q_1\$ in saturation, by itself.
So what values for \$R_1\$?
That depends on whether or not you decide to current-limit the LED. If you do not current-limit it, then the LED is hammered with who knows how much current. Perhaps \$400\:\text{mA}\$? Perhaps more? Perhaps less? I don't know. But it's important because it directly relates to \$R_1\$.
This is why I really think it is important to manage the LED current. Doing so, besides the other reasons mentioned earlier, allows you to actually design a circuit rather than toss one against the wall to see if it works right.
If you do decide to current-limit the LED, say to \$30\:\text{mA}\$ (or some other specific figure you decide on), then we can make some estimate for \$R_1\$.
The point where the two BJTs drop out of saturation and into active mode will be approximately where both of them experience their nominal, active-mode \$\beta\$ values. You don't actually know exact details where this transition accelerates, but it will be close to that.
BJTs vary a lot in \$\beta\$ (\$\pm 50\%\$ or more), but we can put some boundaries down. The NPN will probably be above 150 and below 300 and the PNP will probably be above 110 and below 250. This, combined says somewhere between 16,500 and 75,000 for the combined values. The actual switching point will be someone less than this range, so let's say from 10,000 to 50,000. But if you want to be safer (works with most BJT combinations) then you should pick the larger value: 50,000.
Let's keep the range in mind, still. Just to see where it takes us.
We want \$R_1\$ to supply either no more than \$\frac1{50\:\text{k}}\$ of the LED current or no more than \$\frac1{10\:\text{k}}\$ of the LED current. And if that's \$30\:\text{mA}\$, then \$R_1\$ should be limited to somewhere between about \$600\:\text{nA}\$ and \$3\:\mu\text{A}\$, with about \$8\:\text{V}\$ across it.
That's over \$13\:\text{M}\Omega\$ at the high end and no less than \$2.7\:\text{M}\Omega\$ on the low end!!! And I've already told you that I don't know if that low end is acceptable for any BJT combination -- in fact, it's not safe to use it.
Now, I've no idea yet what Spice will tell me. I've just been wandering in the woods, mentally.
So let's do a design. It's your schematic except that I'm inserting \$R_3\$ and changing the values for \$C_1\$ and \$R_1\$. I'll assume that the LED voltage drop at \$30\:\text{mA}\$ is \$3.2\:\text{V}\$. So \$R_3=\frac{9\:\text{V}-100\:\text{mV}-3.2\:\text{V}}{20\:\text{mA}}=285\:\Omega\$, so I'll call it \$R_3=270\:\Omega\$.
I already know that I'm using \$\text{M}\Omega\$ resistors, so I'm going to set \$C_1=220\:\text{nF}\$ to keep the timing reasonable. (Order of a second or so.) And I already know my range for \$R_1\$ to test.
So let's plug up an LTspice schematic:
And run it for various values of \$R_1\$:
The spice simulation used \$\beta_1=300\$ and \$\beta_2=200\$, above. I didn't vary the BJTs over their \$\pm 50\%\$ \$\beta\$ ranges to see how all the combinations would work out. But the above gives an idea that my thoughts weren't too far afield.
Here is the case where I've reduced the \$\beta\$ values to \$\beta_1=150\$ and \$\beta_2=110\$ (I added another trace for a still lower value for \$R_1\$), and this is for lower \$\beta\$ of about \$-50\%\$:
Note that it does now work for a lower value of \$R_1\$.
And now I've increased \$\beta_1=450\$ and \$\beta_2=300\$ (about \$+50\%\$):
Note that several earlier values that worked, now no longer work. A safe value is around the area I mentioned before.
Also, I could vary the BJT's saturation currents (and should.) But this is enough to get the points across.
Some ideas to experiment with:
  1. Add a degree of freedom by replacing \$R_1\$ with a resistor divider pair, instead. This may permit you to increase the pulse width (making \$C_1\$ larger) while retaining the pulse frequency (by lowering the Thevenin resistance to compensate for the increased capacitor value.)
  2. Add a small amount of emitter resistance to \$Q_1\$ to widen the pulse. Maybe start with \$10\:\Omega\$ and work very slowly upward or downward from there.
  3. Reduce \$R_2\$ by half to widen the pulse.
Each of the above three thought experiments are new to me. I've never considered them, before. But in describing the circuit to you, they all arrived as ideas I knew would do something useful over the period of about 10 minutes. It would be productive for you to ask yourself why these ideas would come to my mind, at all, and to figure out something about why I wrote them as I did. And then to explore, in more detail, their limited range of application as well as how they do anything at all like what I suggest they may do.
jonk
  • 77,059
  • 73
  • 185
    Wow, that's a long and detailed answer, thank you very much! This will take time for me to get through and understand, but I will eventually get back to you. This must have taken you the better part of an afternoon to compose, so thanks again for taking that much time! – Stephan Neuhaus Oct 03 '21 at 15:17
    @StephanNeuhaus Mostly, I want to get across that there are lots of nuances to "simple circuits" like this. For a pulser, you'd need two completely different periods of positive feedback (likely for entirely different mechanisms) to make it work. And it often takes some careful thought to elucidate them. *Attributed to Albert Einstein by Roger Sessions in the New York times in 1950, ***"Everything should be made as simple as possible, but no simpler."** – jonk Oct 03 '21 at 20:27
    Agreed, I'm going to save this answer for a rainy day, go through it bit by bit and make sure I understand, thanks for the time taken! – OwenM Oct 03 '21 at 22:07
  • @OwenM Best wishes! Feel free to ask questions when you have them. – jonk Oct 05 '21 at 04:59
    OK, I've finally gotten the simulator to do it right, and I'm getting much the same diagrams that you are also getting @jonk. Good! (Pro tip: KiCad has diode anode and cathode as nodes 2 and 1. That will obviously not work well with Spice. KiCad stubbornly claims that this is not a bug in KiCad. I disagree.) Now I need to go through your explanation step by step to make sure that I understand everything. Also, I need to build this thing, even through the off-time seems very very short indeed, so not sure if I'll actually see it blink. Thanks a ton again for this very detailed explanation! – Stephan Neuhaus Oct 12 '21 at 12:13
  • And yes, I absolutely see your point that "simple circuits" can be tricky. I successfully built a Joule thief and still don't understand how the transistor turns off. Also, the one that I've built switches at 900 kHz, which is about an order of magnitude faster than I was led to expect from descriptions. AND it only works for battery voltages of 0.7 V or lower, to about 0.35 V. – Stephan Neuhaus Oct 12 '21 at 14:50
  • @StephanNeuhaus You may have to post up what you built. I'm guessing that anything that is close to 1 MHz oscillation has almost nothing to do with design and everything to do with parasitics, construction technique, noise, and/or improper use of an oscilloscope. – jonk Oct 12 '21 at 22:00
I made a few changes to this basic circuit and was able to achieve a flash at about a two second repetition rate and 100 mSec ON time. Here is the simulation:
Flasher simulation
A similar circuit can be built using NMOS and PMOS devices, and can have about 50% duty cycle:
Flasher Simulation NMOS and PMOS
Unfortunately, this circuit is highly dependent on supply voltage. It won't work on 8 volts or 10 volts, without changing R5 and R7.
PStechPaul
  • 7,195
