I'm trying to connect my phone to my portable DAC which has an optical in. I am looking for a solid 24-bit (up to 32-bit) cable for signal transmission, pre-processing. I've researched TOSLINK TX architectures, but not with reference to phone USB power-handling or their expected milliamp/volt consumption.
(As an aside, if there's a cheap OTG cable for USB-C to Micro USB without the power leg on the Micro side, that would be a wonderful solution.)
The problem I'm trying to fix is that my phone's output via standard electrical cable automatically charges the amplifier, draining the phone battery. I'm well-aware I can make and constantly repair my own USB OTG cords and omit the power rail on the micro-USB side, but I'm looking for a lower-maintenance solution.
The reason I say mostly-passive is that the TOSLINK TX device has an internal IC to drive the LED.
It seems there ought not be an issue, but every related device I've seen on the market is $100+ due to its containing an internal DAC, which I specifically don't want...they can't drive my high-impedance headphones. Cries in audiophile
