I'd like to add a zener diode to my tp4056 in order to be able to use the load while the battery is charging.
Context:
I found this post that looked promising however I lack electronics knowledge and I'm not sure I understood the answer correctly.
Here are the steps:
1 Connect your power consumer directly to the same positive voltage input that you connect your TP4056 to.
2 Add a Zener diode between the positive terminal of your battery and that point, too.
3 It's often a good idea to also have another Zener diode at the very power input, so that you're not accidentally discharging your battery into whatever is usually attached there. (I don't see where I should put this one to be honest (between Vin/Vout or Bat+/Vout or something else)
Here's how I think it'll look like:
Questions:
Is it safe?
Where the third point (Zener diode) should be put (if it's necesary)?
Is my schema correct? (Excepted 3 where I need help understanding where to place the Zener)
What type of Zener diode shall I use for 2 (V & W)?
What type of Zener diode shall I use for 3 (V & W)?
Details:
The TP4056 you see in the image attached will be the one used, it's not the old version that didn't include battery protection.
Here's where I would buy the Zener diodes
Update here's the Schematic version (using this documentation):
I've added the first Zener diode (maybe I messed up the side) and the extra wire between vin+ and vout+
