-5
Does the MOSFET gate need a high voltage in order to turn on the MOSFET as well?
What is the difference of high and low side of MOSFET? Is there any effect?
The Photon
  • 126,425
  • 159
  • 304
sean900911
  • 143
  • I think your question relates to the use of a N-mosfet as a high side switch (controlling the positive side of the load). If that is the case refer to [this reply](http://electronics.stackexchange.com/a/95260/33841) for the problems it introduces. – alexan_e Mar 16 '14 at 16:05
High-side switching is when the load is between the drain and the supply, low-side switching is when the load is between the source and ground.
Leon Heller
  • 38,774
  • 60
  • 96
